MES and ERP: Differences, Interaction, and the Role of Detailed Planning
When an order changes at the last minute, the production plan must be adjusted manually. This is still an everyday occurrence in many manufacturing companies. Efficient planning and control of production processes require close integration of MES (Manufacturing Execution System) and ERP (Enterprise Resource Planning) with detailed planning. However, many manufacturing companies lack this end-to-end integration. Data is not automatically exchanged between the systems, so manual intervention is necessary. This complicates production planning, wastes time, and reduces flexibility on the shop floor.
To increase production planning and manufacturing efficiency, it must be clear which tasks each system handles and where its limitations lie. Only then can the interconnection of machines, as envisioned by Industry 4.0, become a reality.
But what is the difference between ERP and MES systems? What role does detailed planning play? This article explains the differences between MES and ERP and shows how your company can benefit from intelligent interconnection.
What is the Difference Between an MES and an ERP?
Both ERP and MES systems have a similar objective: to help companies optimize, control, and monitor processes. However, their areas of application differ significantly.
ERP systems are positioned above MES systems in the automation pyramid. While ERP primarily maps commercial and administrative processes, MES focuses on production processes on the shop floor. In summary:
- ERP processes order and company data.
- MES processes production and manufacturing data.
Therefore, the key difference lies in the core functions of ERP and MES systems.
What ERP Systems Do
ERP systems are primarily responsible for automatically transmitting order data to production. The goal is to improve communication between departments throughout the supply chain. For example, they support:
- Order management
- Materials management
- Purchasing
- Sales
- Human resources
- Finance
ERP ensures company-wide planning and management of resources.
However, an ERP system alone is not enough
While an ERP system can significantly simplify communication and processes between people and machines, However, this also presents a limitation. To remain user-friendly, ERP systems inevitably simplify the complexity of the information presented. Many details of ongoing production cannot be depicted with the necessary depth. For production, ERP requires a complementary solution specifically developed to meet manufacturing requirements.
MES: a Specialist in Manufacturing
The MES coordinates the shop floor in real time. Its tasks include the following:
- Recording lead times
- Monitoring machine utilization
- Recording production data
- Providing transparency regarding ongoing manufacturing processes
- Feeding production data back to higher-level systems
The MES transmits production data to the commercial management function, which is then handled by the ERP system. In this way, the MES primarily creates transparency in production.
MES and ERP: Why the Two Systems Belong Together
Both ERP and MES rely on the automatic transfer of data. They have overlapping functions in some areas, such as materials and human resources management. However, they only provide added value when they interact with each other. ERP provides order data, while MES provides production data.
In many companies, though, this integration has not yet been fully implemented. Without integration, orders must be transferred manually. This creates additional work, increases the likelihood of errors, and makes responding to last-minute changes more difficult. At the same time, the ERP system relies on production data from the MES. Without up-to-date feedback from the shop floor, cost calculations and planning are limited.
Therefore, MES and ERP are not competing systems, but rather complementary ones.
What Role Does Detailed Planning Play?
Alongside ERP and MES, it plays a crucial role in production planning. While rough planning is often carried out in the ERP system, detailed planning considers all available and limited resources when planning and controlling specific orders. This becomes particularly important when:
- orders change at short notice;
- machines break down;
- bottlenecks arise;
- delivery deadlines must be met.
Detailed planning ensures production plans can be adjusted quickly to meet deadlines and reduce costs. This planning is usually carried out via a module within the ERP or MES system.
Digital Detailed Planning with APS Software from DMG MORI
This is exactly where DMG MORI’s digitalization solution comes in: DUALIS’s Advanced Planning & Scheduling System GANTTPLAN specifically bridges the gaps described between ERP, MES, and detailed planning. Production orders are planned transparently, resources are allocated optimally, and short-notice changes are accommodated flexibly.
This solution provides direct access to existing ERP structures for digital detailed planning. Master data, production orders, and operations can be imported and used for optimized production control.
This significantly increases the transparency of the flow of information within production, allowing companies to gain an overview of current orders, processing statuses, and delivery dates at any time.
Why Integrating ERP, MES, and Detailed Planning Is Crucial
The greatest opportunity today lies in optimizing the integration of ERP, MES, and detailed planning. Small and medium-sized enterprises benefit the most from a direct connection between these systems. Interfaces between ERP and detailed planning allow for the efficient management of orders and facilitate seamless communication between machines, production, and administration.
This opens up a new dimension in production planning with real-time information, greater transparency, and increased flexibility. Companies that take advantage of these opportunities early on will secure a decisive competitive advantage on the path to Industry 4.0.
DMG MORI supports manufacturing companies on this journey, from machine integration and digital networking to intelligent production planning. In addition to APS software, DMG MORI offers manufacturing companies the modular MES solution TULIP to digitize and optimize their manufacturing processes. The MES system connects production areas, provides up-to-date manufacturing data centrally, and enables data-driven control of all processes. With the no-code environment, specialized departments can create applications independently for quality management, error analysis, and process optimization.
Contact us to learn how end-to-end integration of ERP, MES, and detailed planning can benefit your company.
