12/19/2022|Digitization
What is the Digital Twin?
Industrial manufacturing is faced with ever new and growing challenges. The shortage of skilled workers has long been omnipresent. In addition, there are shorter product life cycles and higher variant diversity with smaller batch sizes. At the same time, market dynamics and changing supply chains demand ever higher machine utilization rates, greater transparency over production and the ability of employees to perform their tasks in a targeted manner. In this complex environment, the concept of the digital twin is seen as a great beacon of hope. Reason enough to look beyond the boundaries of reality here and address the question: "So what is a digital twin?"
Digital Twin: Digital Model of the real object
Dr.-Ing. Daniel Niederwestberg, Head of Digital Twin in front of the DMU 340 Gantry
The most important thing to say first: measured against human understanding, the concept of a digital twin is inadequate from a technical point of view. Admittedly, it is very much about the transformation of an actual or assumed reality with all its details and properties into digital space. However, such a digital replica would be completely incapable of action on its own and thus worthless.
The Digital Twin only becomes really valuable through the digital model of the real object and its digital image. Digital models are therefore dynamic 3D representations of a real object that can be used for simulations and analyses. The associated digital images of the corresponding real components in turn represent the data captured or to be simulated from these models. Only through the inclusion of digital models and digital shadows of the actual component is the digital twin finally able to improve the products and processes concerned or prevent errors in a continuous control loop of simulation, analysis and optimization on the basis of the information generated.
Customer benefits
The added value to be unlocked is manifold. The DMG MORI DIGITAL TWIN, for example, differentiates its customer benefits into three areas:
- Increasing the number of spindle hours used productively
- Shifting non-production activities such as run-in processes and programming to the virtual world
- Preventing machine downtime due to collisions
- Reduction of component costs
- Reduction of cycle times through process optimization and transparency of cost drivers
- Prevention of rejects through prior simulation and simplified defect detection
- Empowerment of employees
- Reduced defect rate through early training and, if necessary, ongoing training
- Simplification of complicated work tasks by increasing transparency
Realistic test machining and trainings
In concrete terms, DMG MORI DIGITAL TWIN can therefore be used, among other things, to develop a planned machine completely in virtual space and to simulate, analyze and improve its capability with virtual controls, tools, clamping devices and workpieces until the result meets all expectations of the innovation. Every keystroke on the control, every tool change, every clamping situation, every axis movement, every spindle load: Everything can be digitally scrutinized and optimized with and on a Digital Twin. And that, mind you, even before the production of the "real" machine is tackled.
With DMG MORI DIGITAL TWIN, a planned machine can be developed completely in virtual space and its capability simulated, analyzed and improved with virtual controls, tools, clamping devices and workpieces.
Furthermore, customers can then perform realistic test machining of their components while the machine is still being built. They can perfect CNC programs for their new machine and train their staff even before it is installed on their own store floor. And once installed, the machine can continuously communicate information to its Digital Twin about the status of the machine and jobs in progress. The data obtained in this way could be used to continuously improve processes and make well-founded operational and strategic decisions.
It almost seems as if the possibilities of virtuality only end at the limits of human imagination. Especially since digital twins are not loners, but can also interoperate with and among each other on the basis of a common syntax and semantics. What has been described above for the machine therefore also applies in a figurative sense to robotized manufacturing cells or to automated manufacturing systems with any number of machines, pallets and tools, as well as to autonomous transport vehicles and their routes within a store floor.
The only prerequisite is that every element of a system and every property of a service or process is also available with the associated data as a connectable digital twin. In any case, the more and the better the available information from the past and the more substantial the determined data from the present, the "smarter" the algorithms become and the more precise the analyses and the more accurate the answers. This is especially true when it comes to recognizing events even before they happen in reality.
Digital Engineering by DMG MORI
Definitions
What you, the reader, are still missing after all these explanations is a clear and concise definition of what a digital twin is. But even the scientific community has not really succeeded in agreeing on a clear and definable answer. Of course, we don't want to deprive you of a small selection of the definitions we have researched:
A digital twin is a virtual representation of a physical object or system - but it's much more than just a high-tech look. Digital twins use data, machine learning and the Internet of Things (IoT) to help companies optimize, innovate and deliver new services.
Web of Things (WoT) Architecture W3C Recommendation. April 2020
A digital twin is a virtual replica of a physical entity or system. The digital twin is much more than a picture, blueprint or schematic: It is a dynamic, simulated view of a physical product that is continuously updated throughout the design, construction and operation lifecycle. The digital twin and the corresponding physical object exist in parallel and evolve together as the physical product progresses and matures.
Saracco, R. Digital Twins: Bridging Physical Space and Cyberspace
A digital twin is a virtual representation of a physical object or system throughout its lifecycle that uses real-time data to enable understanding, learning and reasoning.
Mylonas, G.; Kalogeras, A.; Kalogeras, G.; Anagnostopoulos, C.; Alexakos, C.; Munoz, L. Digital Twins from SmartManufacturing to Smart Cities: A Survey 2021
A digital twin is an integrated multi-physics, multi-scale, probabilistic simulation of a system in its as-built state that uses the best available physical models, sensor updates, fleet history, etc. to map the life of the corresponding (flying) twin
Glaessgen, E. H., Stargel D.S., The Digital Twin Paradigm for Future NASA and U.S. Air Force Vehicles», American Institute of Aeronautics and Astronautics, 2012
Read more now
Activate technical data now
Activate download now
Activate history now
Activate favourites now
